DIY turbo: tuning
DIY turbo: tuning
oil system, charge tube, pcv delete and everything is done few final questions before i weld in the turbo on saturday. I only plan on running 5psi to start what do I need to take care of before tuning? will I be fine without a tune for a few days at 5psi? i've ordered a 2 bar map sensor but it won't be here till later next week at which time i was going to get it tuned
Former Vendor
You will need to go in and move the timing tables. Do not remember where is was in my efi live, I just remember this table that put the timing to ZERO and will freak you out, the firste time you hit it. I went in and put all those zero's to 10' and ran fine. I am sure someone will be able to into great details.
The truck was an 02 6.0L
Ricky
Ricky
Originally Posted by ogkevin13
i would get it tunned unless u stay out of boost!!!! (which is hard for me ) do u have ne pics of the map?
Moderately Differentiated
As long as you stay out of PE then the motor will be fine but without those tables being adjusted you will cetainly fry your motor. I think PE on a stock tune kicks in at around 50% throttle or so, Im sure someone on here knows the exact TP%.
Your question is it safe at 5psi. NO! I wouldn't suggest running a stock N/A tune in any way shape or form with any FI setup. Take your time, get it right.
ordered a 2bar map? it won't work (well, it might work, but you'll probably regret it) without the proper operating system anyway. Asking for trouble IMO unless you do it all with tuning done (or done close enough) as well. You abandoning the MAF then with 2 bar?
