Does Anyone Have a VE table for a 6.0 with a Supercharger Please send
Originally Posted by dc_justin
Who told you this?
Tuning trims via the IFR seems to have been the old way of doing things, before newer and better tuning methods have been discovered/created. It's more of a bandaid fix than a proper solution to the problem...
Why not leave the IFR accurate and tune the real areas that are incorrect, the VE and MAF Frequency Calibration tables. You'll end up with an all around better tune.
EFIlive has an AutoVE feature that hooks up with a wideband. You drive around and the table automatically fills in. I will be trying that as soon as I get the wideband next week. Has anyone tried this?
Hello Dave
Adkoonerstrator
Isn't the VE table what the computer would fall back on if there was ever a MAF failure? It would make sense to me to get it as accurate as possible for whatever setup you're running even if you intend on still running the MAF once the VE is tuned. IFR is a quick and easy way to make changes with fueling but, not completely the right way IMO. I wouldn't mess with the MAF calibration tables. The transfer function of the MAF is what it is "x air in, y frequency out". Unless physical changes are made to the MAF the values should not be changed. While the IFR and MAF tables can be used to make changes in fueling they are not the correct way IMHO. I'd use the IFR before messing with the MAF calibration though.
Moderately Differentiated
correct me if i am wrong here...but we are modding our vehicles beyond a paint job..usually in case past the point of oem specs. ie;map sensor is pretty much completely useless once you go FI with so much boost, maf is isn't helping out once you go past a certain freq....ect ect ect...I am just saying wouldn't it make sense if you have the time and the menas(soory about that sp...it's hump day...been drinking) to correct or "adjust" each table that you are blowing away? ve? maf? I have a return fuel system, so it seems to me messing with ifr is a bad idea. maybe I am wrong.
Hello Dave
IFR should accurately reflect the flow rates of your injectors at the given vaccum. That is how the PCM determines how to control the injectors for a specific airmass. By adjusting the IFR, the PCM may think it is fueling for 50 g/sec, when in fact because of your adjustment, you're fueling for an inaccurately metered 57 g/sec.
Additionally, adjusting the IFR only gives you 2D of control, whereas VE table is 3 dimensional.
Working with the tables is pretty cool. You can flip back and forth between
the table and the 3D chart to get a better idea of what your changes are doing. Aso you can view your VE as %, g/sec/, g/cyl or g*K/kPa. The 3D charts have very different appearances. You can select cells on the 3D then toggle to the chart to check/modify the values of those cells. Very easy to work with once you get the hang of it.
Hopefully I can finish the VE tuning this weekend.
Originally Posted by DrX
BTW. When you are setting up the BEN map for Auto VE don't forget to add the extra kPa labels up to, say 200, if you want to tune for boost also. Following the tutorial only gets you up to 105 kPa.
Are you using the Saturn Ion 2 Bar sensor from the dealer? Which table is this adjustment required. Please Advise.
Thanks
