Done deal.. Maxed out 4.8L/76mm Magnum. Next?
#61
#68
Thanks guys, well see if it can perform as well as she looks!
As for $$, looking at 1600. 1700 for polished, 1800 for polished and coated exhaust housing. I plan to blanket the rear, so I just opted for polished.
As for 9s, well see man, you know i'm all about it! Once I get it (fingers crossed) I'll start building that 328 this winter.
#69
As far as the diff is concerned, are you using the stock rack and pinion?
We have some decent options in the GTO. I think stock I have 3.46 or something.
For the turbo setups, isn't it usually better to stay in the lower gearing? Would there be a benefit to get a higher gear ratio like the 3.73, 3.91, 4.10?
What is your alls truck stock diff ratio?
#70
Or axle gear ratios?
Trucks usually come with 3.23, 3.42, or 3.73.
For turbos usually 3.42 or 3.73 work great since turbos need load to make boost.
