Dual Walbros No Hobbs
Old 04-05-2010 | 10:17 AM
Last Call's Avatar
TOTM: January 2007
What about the Bosch 044? Anybody running one of them?
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
Old 04-05-2010 | 12:03 PM
1_bad94Camaro's Avatar
11 Second Club
I'm running the dual wabro pumps with the hobbs switch. second pump comes on at 4 pounds of boost. I have room to add a third one if needed.
Old 04-06-2010 | 08:54 PM
Sleeper04's Avatar
How do you ahve that much room? Are you running a return setup? It sounds like once you hit a certain point, you have to bite the bullet and spend the money to upgrade your fuel system so that it can handle the additional HP. Nothing available that's a direct swap or drop in and go type thing. I'm not the most mechanically inclined which is why I'm hesitant to mod the bucket and go duals w/hobbs. Thanks for all the comments!
Old 05-06-2010 | 02:28 AM
Atomic's Avatar
I have a gauge for that
I wonder what would happen to the stock regulator if you threw the stock pump and a walbro 255 in parallel for a returnless system...
Old 05-07-2010 | 10:11 AM
TURBHOE's Avatar
it would make a tahoe go 12.33. lol thats what i have on mine. hobbs for the walbro though. if you run them both while not in boost the pressure is up there. i converted mine to return style awhile back. i think if my return line was bigger i could run both pumps on all the time, but i'm good with my hobbs switch.
Old 05-07-2010 | 10:27 AM
sharpshooter's Avatar
Their are quite a few of us running single in tank 044's with no problems.
Old 05-07-2010 | 11:45 AM
Most Hated's Avatar
i run dual walbros no prob and no hob switch
Old 05-07-2010 | 11:49 AM
Atomic's Avatar
im getting roughly an 8psi drop at wot with just the single walbro, and adding the stock pump back would be free since I already have it
Old 05-07-2010 | 05:22 PM
MGMC's Avatar
12 Second Club
I just converted over from a returnless style.
current set-up;
255 intank
-8feed line
044 on the frame rail w/ jayracing fp wiring
filter
fast fuel rails
-6 return
aeromotive fpr
-6 back to the tank
the swap was easy, there is soo much room in the bucket now since the stock regulator and filter are gone
Old 05-13-2010 | 08:38 PM
Sleeper04's Avatar
Is this on a returnless system? Did you have to mod the bucket or did it drop right in? Anything else that you have to do?
Same questions as above...Using the stock regulator?
I've been putting this off and running on low boost until I figure out a solution. Thanks for the feedback!
03sierraslt
14
10-09-2015 05:53 AM
blackedoutchevy22
10-01-2015 08:07 PM
sTNT971
09-26-2015 04:22 PM
97_ek
09-23-2015 09:16 PM
Quick Reply: Dual Walbros No Hobbs
