Dual Walbros No Hobbs
What about the Bosch 044? Anybody running one of them?
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
How do you ahve that much room? Are you running a return setup? It sounds like once you hit a certain point, you have to bite the bullet and spend the money to upgrade your fuel system so that it can handle the additional HP. Nothing available that's a direct swap or drop in and go type thing. I'm not the most mechanically inclined which is why I'm hesitant to mod the bucket and go duals w/hobbs. Thanks for all the comments!
it would make a tahoe go 12.33. lol thats what i have on mine. hobbs for the walbro though. if you run them both while not in boost the pressure is up there. i converted mine to return style awhile back. i think if my return line was bigger i could run both pumps on all the time, but i'm good with my hobbs switch.
I just converted over from a returnless style.
current set-up;
255 intank
-8feed line
044 on the frame rail w/ jayracing fp wiring
filter
fast fuel rails
-6 return
aeromotive fpr
-6 back to the tank
the swap was easy, there is soo much room in the bucket now since the stock regulator and filter are gone
current set-up;
255 intank
-8feed line
filter
fast fuel rails
-6 return
aeromotive fpr
-6 back to the tank
Same questions as above...Using the stock regulator?
I've been putting this off and running on low boost until I figure out a solution. Thanks for the feedback!
