Dual Wastegates and STS EBCS
#32
I bought my second spring from a local tuner shop (pricy) which was good for 3.5 psi. On a side note, my stock 5.7 engine/heads was nearly maxing out the single WG. I am installing a 2nd one this spring. I believe having more wastegate capacity will allow the boost to climb much faster and stay put rather than having the wastegate go wide open early and the boost slowly rise to the set point. With nothing else changing, 2 valves should have quicker boost buildup than 1 valve that opens 100%.
#34
It was the case for me earlier where I needed to set the wastegate to 5 psi to maintain 8 at full throttle. A larger wastegate could have been set to 8 so the boost could have snapped to and stayed at 8 psi instead of slowly levelling off at 8 psi. If his single wastegate turns out to be undersized, 2 wastegates will provide quicker boost.
