Dyno vid, 08' SD AWD, P1sc
Just wondering why so weak on the timing? She looks like when it drops into PE it's puffing some black smoke I am just guessing by the video she's on the chubby side? I would guess with a nice work over on your timing table and leaning her up a bit you have another 40 hp in it.
Hat's off to you glad to see some prochargers getting out there showing what they can do on the new body style trucks!
Jeff
1 Post
That is the baby procharger intercooler. I think they call it the two core. I personally don't like them either they don't offer enough surface area. Also good move on the blow off. I have picked up as much as 2 psi on the same pulley swapping out the bov. I am defintely looking forward to the results
which front mount are u getting? im also planning on the same exact setup but with a 3-core intercooler , maybe low compression pistons and forged rods for a higher psi
i really wanna hear that thing when u let of the gas i bet it sounds sweet!
The front mount is from Frozen Boost. Core is 24" x 12" x 4", 3" inlet and outlet. Fits perfectly. The final welding should be done tonight on the new hard pipes and then off to powder coating. I'll then re dyno the truck see if its better. Run it for a while then I'm going to take it off and add headers and a VVT cam. Being we have a dyno we can spend quality time on the dyno fine tuning the VVT on the truck. and the 6L80E. Should be a fun summer. I'm hoping to get around 425 with cam and headers.
I'll get some video of the truck once it's all finished.
Thanks
Jeff Smith
New intercooler is doing exactly what its supposed to, I'm roughly 20* over ambient, instead of 60-70* over. We need to retune the truck being I installed a 2010 denali MAF as its the card style. Removed two extra couplers that I didn't need to have blow off. 10.0 A/F currently and maxed out 60lb injectors, Boy I'm not looking forward to dropping more on bigger injectors!!! currently its commanding 5* of timing. Almost to 500AWHP
Well final numbers are in, I need a fuel pump, Thinking Flex fuel 2010 pump. As soon as we walk into the throttle for a pull pressure goes straight to 60psi and then by the end of the run we are at 35psi. Truck leans out and we are done... Everything is working great minus the fact that I need to spend more money. I'm hoping to take it to the track in the next two weeks. I'll post the results in this thread. I hit the numbers I want, zero knock 16* of Timing.
Jeff
Jeff
