E85 fuel system for boost
#25
i just got done doing a larger fuel system for my e85 set up. i went dual in tank 255's both running all the time (heard horror stories of hobb switch failing) hot wired to the back of my altinator. i did -8 line all the way to the rails upgraded to ls1 rails with a -6 return and bought some siemens 80# injectors @ 45 psi and run my fuel presure at 58 psi at idol . here is my build thread if you want to check it out ... Fuel System Build - SilveradoSS.com
lxcoupe
07-21-2015 02:12 AM
