Eboost Street connection
Old 05-20-2013, 07:21 PM
GMCtrk's Avatar
Default Eboost Street connection
To those of you using this unit, did you hook it up via the single port or 2 port method?
Old 05-20-2013, 07:27 PM
Mod with training wheels
smokeshow's Avatar
2 port for the win
Old 05-20-2013, 07:29 PM
GMCtrk's Avatar
What makes it better than the 1 port? The manual says that the 2nd 2 port combination is for the widest range of boost. What's the drawback with that? 1st 2 port combo is for setups with high back pressure. I guess they want you to try multiple setups to see what works best.
Old 05-20-2013, 07:32 PM
smokeshow's Avatar
No drawback... Just allows minimum boost to be lower in case I want to tow stuff. I can run as low as 5psi, or have the solenoid start putting boost to the top of the wastegate to hold it closed above 10psi.
Old 05-20-2013, 07:40 PM
Ferocity02's Avatar
Here's a thread I made about this very same question... https://www.performancetrucks.net/fo...umbing-506387/
I am currently running a single port setup with the light wastegate spring. At the lowest setting it will do ~4psi. Haven't tried the highest setting yet, I'm still working on the tune. I ran both wastegate lines to the solenoid so I can quickly swap the lines around to run 2-port. The one-port method uses boost to open the wastegate, while the 2-port method uses boost at the top to offset the boost at the bottom, giving you a wide range of control I suspect. High back pressure will try to open the gate, hence the desire to use the 2-port hookup with high back pressure. The third option is to run the top port to boost and vent the bottom, this should keep the gate closed the longest.
Old 05-20-2013, 07:49 PM
GMCtrk's Avatar
I think I'll start with the 2 port method.
That's really nice that you can get down to 4 psi. I see 7 psi with a peak of 8.5 psi with the lightest spring in my jgs 50mm. I'd like to see 15 psi with the controller and it should bring the boost in faster as well.
Old 05-20-2013, 09:13 PM
Ferocity02's Avatar
Bottom port of the wastegate to the compressor housing, top port vented, with the lightest wastegate spring, with the controller on the lowest setting will get you the lowest boost, short of running no spring in the gate.
Old 05-29-2013, 07:01 PM
GMCtrk's Avatar
Bumping this back up because I got the stuff today.
I'm guessing you guys have the solenoid mounted underneath the truck? I'm thinking somewhere on the passenger frame rail near the WG should be good. They really don't give you too much vacuum hose with the kit which would have been nice.
Old 05-29-2013, 07:07 PM
I have a gauge for that
Atomic's Avatar
It needs to be close to the WG to work the best. Mine is right beside the turbo/gate, maybe 12" of hose.
Old 05-29-2013, 07:43 PM
smokeshow's Avatar
Mine is under my intake manifold. Had to buy more vacuum hose. Probably 4 feet to each turbo...
Quick Reply: Eboost Street connection
