EFILive tune for Kenne Bell
I am getting ready to install my old style Kenne Bell supercharger on my 2004 Escalade ESV. Does anyone have a KB tune I can use as a start platform. Preferably a 6.0/drive by wire/towing.
Primary use is hauling enclosed 24' trailer and getting out of other peoples way.
Here is the superchips tune that came with my Radix. It is 6.0L, 4l80e drive by wire straight out of the handheld. Look through the injector scale(make sure it matches for flow rate and manifold ref. fuel pressure) and trans pressures(maxxed out by superchips) before you flash your truck. There is not much changed in the tune besides PE throttle enable %, PE vs. RPM and shift pressures.
You are going to be running 43lb injectors correct?
Thanks for the tune. While the trans is not the same the other values should help me start. I am currently working on the trans making logs while hauling the trailer loaded with the car. Everything is fine in NA form except the OD lockup. On some days it stays locked and other days it starts to rev up before the 4-3 shift.
Regarding the injectors I do have the 8.1 Marine injectors from KB.
03sierraslt: As I get closer to finalizing my tune I will probably contact you for more info, thanks for the help.
JFortner5
08-20-2015 06:13 PM
