Electric Superchargers (No, really...)
I mean, how much HP Is required to turn the supercharger to produce a certain amount of boost in PSI. For example, to push 5psi - the supercharger consumes 20hp... or something...
UPdate; nevermind, I jumped the gun, thanks for the info.
Try and measure the CFM at the throttle body on a bone stock 5.3 at 6000rpms.
Start there and then you will know how much airflow you have to exceed to produce any measurable amount of boost.
Once you figure that out let us know.
And once this electric SC is in place, how does the engine go about getting air while cruising at light throttle?
Is it goin to have to pull air across the dead supercharger?
There is no set figure, because there's no sustantial information on airflow from extensive testing on brushless superchargers. It's not like comparing turbos, where you can go off of set variables. 100 HP is 75KW--doesn't matter what, who, or where you are dealing with. That's a set figure. I think it's getting lost in translation here. To produce 5 lbs. of boost, with the numbers I posted, it proves that you'd have to have a stupid amount of amps. It's not going to happen, even remotely efficiently.
EDIT: Just read Nonnie's post, and he said something that I failed to mention earlier. When not active, this essentially becomes a **** block of airflow.
I know some R/C Ducted Fan jets can produce 1200cfm using around 2kw. Of course I know that is not creating pressure, just moving air.
In regards to your question on the dead supercharger, it would have to be either bypassed with some type of check valve situation, or operating at a low power setting... without having to create boost, I wouldn't think the power requirements would be too high. Just thinking out load before anyone throws **** my way.
Right, but there must be some testing done on centrifugal superchargers currently in use, meaning the parasitic drag. Lets assume for a moment that an engine is turning the supercharger but the boosted air is going elsewhere- not creating more power for the engine. How much power would be robbed by turning that useless supercharger? If we can determine how many HP is robbed from a typical setup to produce 5 PSI... then we can use that info to determine what type of electrical requirement there would be to do the same thing electrically.
Here is an interesting example.. it can't require THAT much power to produce boost. Here is an air compressor that can produce 99CFM at 132PSI, using 25HP.
FREE SHIPPING Quincy QGS Rotary Screw Compressor with Dryer 25 HP, 208/230/460V 3-Phase, 120 Gallon, 99 CFM, Model# QGS25WD | Air Compressors 50 CFM + Above | Northern Tool + Equipment
Seems that producing much more CFM at a much lower PSI (5-10) would be dramatically easier...
I've thought and thought about this before, and it's really just a pile of work that isn't capable efficiently or in a cost-friendly manner, just yet. Sure, all new things are nothing but research and work, but this is almost like a machine that runs at 100% efficiency at this point--not possible in the real world with any variables outside of a vaccuum.
Tin Foil Hat Wearin' Fool
I like your idea, I know very little about electricity. Just remember, you only need less than a minute of power, a 1/4 mile or pull on the highway may be 15 seconds and I doubt you would do too many of those in a row. Using a capacitor type source instead of running off the car battery is a better way to go like you're talking about.
Mod with training wheels
The biggest reason why electric superchargers don't exist is due to the energy losses during the conversion. A supercharger is a mechanical device, where the belt just moves a pulley. For an electric supercharger, mechanical energy would have to be converted to electric energy and then back into mechanical energy. The inefficiency of these conversions is huge and would not net a feasible amount of power gain (if any) when it finally makes its way back into the mechanical form.
