ENG. TORQUE TABLES using HP TUNERS
Hoping someone here uses HP tuners 1.0. The tuner will not allow me to set the max engine torque above 640. The same for the max eng torque VS rpm VS gear tables. Appreciate some help.
If you want to blow up your trans, zero out the "Spark Retard vs. Torque Reduction" table. Zeroing this table will also eliminate any other torque reduction, like traction control for instance.
Or you can leave this table alone and in "Transmission", under "Torque Reduction", you can lower the numbers to firm your shifts.
Is that what you're trying to do, make it shift harder?
The shift is firm enough, or at least it was when I had it in my truck. Its know in a 260z project. My concern is the engine might exceed the "640" max tuning tables. Thanks again for the help
dantheman1540
09-18-2015 03:03 AM
brandon_6667
09-06-2015 04:49 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
