Engine surges on start up then revs high w/Radix
This started happening recently. I turn the key and the engine "stutters" sounds like it's about to die, then all of a sudden surges and rev's to about 1600-1700RPMs. I've had the Radix on for about 2 months and it just started doing this. It runs fine once it's been running, this only seems to happen when i first crank the engine. I'm not sure if it's fuel pump related, but my fuel pump is louder than ever. At idle i can hear it whinning/humming and it's louder than my magnaflow (at idle of course). Called Magnuson and they said it's the first they've heard of someone being able to hear their fuel pump.
Anyone have any ideas about the surging/stuttering issue on start up?
Destroyer of Transmissions
Not sure on the surging. Sounds like a possible vacuum leak. Any recent changes or work done.
The fuel pump...if you mean the in-line pump then yes, it whines sometimes and sometimes it doesn't. Mine has done that since install. More noticeable when parked running next to a wall, like a drive thru etc....
My pump is not inline, its the replacement pump located inside the fuel tank.
There's been no recent engine work done. I thought maybe it had something to do with the weather, but it's gotten warmer not colder. I should clarify that after it surges to 1600-1700 it comes back down to a normal idle and sounds and drives just fine. It's just at start up when it sounds like it's going to die, revs high, then comes back down to normal. It only happens the first time i crank the engine. If i drive around a bit, cut the engine, and then start 'er up again it sounds perfectly normal.
Found this thread in "Tuning", sounds like we have similar problems regarding the hiccup on start up and taking off when the engine is cold. I'm still running the stock tune that came with the Radix with nothing changed except tire size which i reprogrammed for.
https://www.performancetrucks.net/fo...d.php?t=389447
Former Moderator :(
Check your IAC count. You may need to clean you throttle body if its dirty or just turn the idle screw on the throttle body in 1/2 turn an that should fix it, this is a very common problem.
blownerator
2006 is DBW, no screw to turn
Where in so cal are you xsports33? If you are local to LA come on by and I will fix it for ya.
Former Moderator :(
