explain meth to me.
#31
Meth won't do you much good on an N/A set up as the point of it is to keep intake temps down as you are in boost. It also assists your injectors by providing and alternate "fuel" source. The more concentrated your mixture, the richer you will run. You can use WW fluid but as Parish said it can be a little inconsistent. I have been running WW fluid in mine with no issues at this point. If you are tuned for meth and run out don't get into boost or . Kits run anywhere from around $180 to $500+. It's probably good to get a variable controller that adds more meth as boost increases instead of an on off switch. Not sure if there is something that allows it to come on when IAT's get to a certain point. If it comes on when there is not enough air flow, it will cause combustion quench or bogging down. Bottom line, get it, tune for it and watch your wideband!!! Sorry so long, just trying to cover everything!!!
#32
Truck Sponsor
Not sure I follow you there, if you are tuning it for meth then when not running meth its going to be lean. If you use just a very little amount of meth then I could see it being ok but if its enough to make it worth while its going to be LEAN if meth is not being sprayed... Am I missing something? Please correct me if I am wrong.
What I was trying to say, is if you are dialed in on your turn (no water/meth) and then you add it the air fuel will not change any huge amount. So you would not go from running a 11.8 to a 10.0 on your air fuel.
Now if you tune for the water/meth injection and its not there then yes you will be a little lean with pretty much the same type of swing.
Straight meth is a little different, depending on just how much you have to add. If your regular fuel system has small injectors on there and you are running straight meth and a BUNCH of it to off set those injectors then again hole another ball game. if its missing that would be bad for sure.
Small swings in air fuel usually do not cost you tons of power.
IF one has access to it, going to E85 is a great thing for boosted guys.
#35
Registered abuser
why not just use some FAI spec (0% nitro) model airplane fuel? sure theres a little bit of bean oil in there, but thats probably a GOOD thing. Its also a much higher quality all the way around and exactly consistent.
and if you're feeling ballsy, pick up some 10% nitro
#37
#39
[QUOTE=ramsey rider;3884104]parish this is what im trying 2 findout here myself .what is pure meth,and were do ya get it .im looking too try it but idk what product 2 look for .
VP Race Fuels M1: http://www.vpracingfuels.com/index2.html
