fast spool 5.3?
Old 08-16-2024, 01:35 PM
twigy's Avatar
I have a 7675 on my truck spool is very fast but I'm also tapped out at like 650-700 hp with E85. I wish I would have done an 80+ now.
Old 08-17-2024, 08:45 AM
IIGW's Avatar
any specs on what youre truck engine is?
Old 08-19-2024, 05:27 PM
Fullpower's Avatar
I have a 7675 on my truck spool is very fast but ...................
How'd you get the turbo to light of QUICK ? Did it take some fine tuning to get the SPOOL you wanted ?
Care to show screenshot of your spark timing table ?
What torque converter are you using ?
. Thank you.
Old 08-22-2024, 12:10 PM
twigy's Avatar
Fully forged 5.3, Circle D Triple Disk 3400 Stall, LS1 Heads with valve job, BTR Stage 2 cam, custom cold side and exhaust. My build thread is on here few post below if you wanna look at it. I'm on 17lbs at 19 degrees so semi-conservative about to turn it the rest of the way up to 20lbs and I should be mid to high 700s.
IIGW (08-22-2024)
Old 09-02-2024, 04:54 PM
Fullpower's Avatar
F I'm on 17lbs at 19 degrees so semi-conservative
What fuel are you using @ 19 degrees spark on 17 PSI manifold pressure?
Are you running straight methanol ?
MikeGyver (09-03-2024)
06murder
07-12-2024 12:25 PM
fctry286
11-27-2014 01:11 AM
SSCUSTOM6.0
10-24-2007 08:09 AM
parish8
34
01-08-2004 11:56 PM
Quick Reply: fast spool 5.3?
