A few quick question's for radix guys
Say fellas I have a few quick questions for those radix guys out there. Question one is about the pcv valve. Mine doesn't have anything on top of it. I thought it has a hose going somewhere on it, but I can't remember. I will attach a pic to show ya what im talking about. Second question is I installed the 3" pulley on my radix last night. I am only getting about 6psi of boost. I was getting 4.5-5psi with the 3.33 pulley. I know boost is only a measure of resistance, but I figured a drop in .3 would net me more than 1.5psi of boost. I have long tube headers, high flow cats, and a magnaflow muffler, so I have free flowing exhaust. I was gonna measure the new pulley in case they sent me the wrong one, but I can't find my damn tape measure. Just curious if I am doing something wrong here, or thats normal on a LQ9 6.0 Will attach pic of pcv valve Thanks for the help,
Sam
Sam
Should be a hose from the valve cover nipple to the back of the blower j-tube.
Not sure exactly how much the .33 smaller pulley would be good for on a 6.0, but I would guess an extra 2 psi if at the same ambient temp and altitude.
Not sure exactly how much the .33 smaller pulley would be good for on a 6.0, but I would guess around 2 psi if at the same ambient temp and altitude.
Ok it seems there are two outlets on the back of the J tube. The left one has something connected to it and the right outlet has a cover over it. I took the little rubber cover off and it looks like the same connector as the pcv valve. Looks like I will just find me some hose and run a hose. I have some extra hose off my trans cooler I didnt use mabye that will work.
Originally Posted by trever1t
Ditto on the breather hose to the rear of the J-tube.
Pulley is not marked with size? I would think you'd be up ~8lbs with 3" pulley. Did you swap belts?
lxcoupe
07-21-2015 02:12 AM
