which FI is better for a stock 5.3
Old 09-08-2010, 11:38 AM
  #31
charcold-bowtie's Avatar
Originally Posted by Spoolin
This guy is all over the place with what he wants. Kinda hard to narrow it down for him if he's unsure about what he wants.
For 13K I would buy a tranny for $5K, get some fuel supporting mods for $2K, upgrade the cooling system for $1K, spend $1500 on valve train upgrades and cam, and spend the last $4500K on a turbo system.
What the hell are you doing to the cooling system?
Old 09-08-2010, 11:55 AM
  #32
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Originally Posted by AKlowriderZ71
I've been running low 12's on my stock 140K mile G80.
Youre in the vast minority that havent had problems with their G80, youre living on borrowed time or you never beat on your truck except in a straight line. Most people blows theirs playing around where traction is different between the two wheels. I blew mine taking off at WOT on the side of the road with a tire in the grass, other people in water and others nailing it around corners.
No ****, an 06 already has the big radiator and efans
Old 09-08-2010, 12:14 PM
  #33
TURBHOE's Avatar
and you probably run in 4hi at the track. parish's while in the 10's lasted a long time in 4wd also. but one good 2wd play day and it was done.
i installed a 130ish g80 from a friends truck into mine when my detroit went out (due to broken axle), at the time i was 2wd (removed all the awd parts). i broke it and never went to the track. the walls that separte the side gears broke off. so now i went back AWD and a trutrac. i say its better to replace just it now instead of it and probably gears later.
Old 09-08-2010, 06:23 PM
  #34
06murder's Avatar
turbo is to much work n ****....does it have to be low compression and wha not?i was thinking bout going to get an jk 6.0 and put an 1900 on it...get an good tranny n conver, 3.73s...that should be bout what 11,000? take the rest to the strip club
Old 09-08-2010, 06:28 PM
  #35
I have a gauge for that
Atomic's Avatar
im running a 11:1 408 with a 1900 at 7psi as my DD if that tells you anything
Old 09-08-2010, 06:43 PM
  #36
06murder's Avatar
how much is somtething like that i really want an 408....and a 1900...what u run 11s?
Old 09-08-2010, 06:45 PM
  #37
Atomic's Avatar
I have around 11k in it. dunno what it runs, but feels damn fast
Old 09-08-2010, 06:58 PM
  #38
Laid Back
Beatdown Z's Avatar
6.0 with a TVS1900 or appropriate sized turbo will def get the job done.
Old 09-08-2010, 07:53 PM
  #39
11 sec. Truck Mod
TIM Z's Avatar
Damn theres so many ways you can go.
Is this truck going to be a drag truck or a daily driver?
I would do like mentioned earlier and do a cam/springs and either Blower or a turbo with 10- 15 PSI.
And have a good trans built along with a triple disc precision industries converter.
Hell run the 5.3 you have , and if or when it gives up, you can pick another one up for around 500$ and then put some forged pistons in it and turn up the boost more!
Dont forget you'll need Gauges, fuel system upgrades, Exhaust .
You dont need to blow all your cash to make big power with an LS engine!!!!
Old 09-08-2010, 08:04 PM
  #40
06murder's Avatar
i went to the part store to c if the stupid ***** got an 6.0,they have on for an ss silverado long block for 3200???how good is an 6.0?
Quick Reply: which FI is better for a stock 5.3
