FI guys w/tranny cooler plumbing ??
Old 07-05-2010, 11:33 PM
  #21
Baltimore Whore
Mangled03gmc's Avatar
No bypass for me, I opt to run it sep, not through the trans. I am about 140 all the time. Some will say its to cold, but all is good
Old 07-05-2010, 11:35 PM
  #22
TX Tahoe Z71's Avatar
H/e mounted up with light coat of black paint to keep a somewhat sleep look behind the Chevy grill, fabbed the top mounting bracket with a piece of flat stock bent with channel locks:
The trimming that had to be done on the back side of the plastic grill to clear the h/e (a lot of trimming):
H/e squeezed in there:
Done! Can't even tell there is a h/e behind there
Old 07-06-2010, 06:09 AM
  #23
11 sec. Truck Mod
TIM Z's Avatar
^^^ I had to chop up the back of my grille a lil bit too to fit my Heat exchanger.
Im going to mount a tru cool below it and maybe put a few openings in the lower valence.
Old 07-06-2010, 06:47 AM
  #24
Doobie's Avatar
Here are some pics of how I mounted my TruCool. My Radix HX is mounted in front of this. You can see the bypass under the cooler. Will post more pics of Radix HE mounted in front of this. I purchased the mounting brackets from teesee150 for an easy-clean install.
Attached Thumbnails FI guys w/tranny cooler plumbing ??-100_9656.jpg   FI guys w/tranny cooler plumbing ??-100_9654.jpg
Old 07-13-2010, 01:56 PM
  #25
I have a gauge for that
Atomic's Avatar
Magnacharger hex in front of the trucool 40k
Old 07-13-2010, 02:47 PM
  #26
Doobie's Avatar
I am using the same setup as Atomic and TX Tahoe Z71. I'm thinking about moving the Radix hex to the lower valance. I'm concerned about having 4 hex in succession and the last one(engine coolant radiator)getting enough air flow. Not quite sure how to carve up the valance and still have it look good.
Old 07-13-2010, 03:46 PM
  #27
SILVERADO11's Avatar
wow the cts-v H/E is huge!
BKnBLK05
12-28-2015 08:52 PM
Go5.3tt06
09-12-2015 09:29 AM
fillpot
07-26-2015 07:21 PM
lxcoupe
07-21-2015 02:12 AM
GM-only
07-19-2015 10:48 PM
Quick Reply: FI guys w/tranny cooler plumbing ??
