FI'd LS9 for ZR1
#32
Tin Foil Hat Wearin' Fool
Anyone notice the blower pulley looks to be a pressed on type of deal? Looks like they are trying to make it tougher for people to put on a different pulley. Wonder if there is any sorta tamper device built in that "breaks" if you mess with the pulley? NO WARRANTY CLAIM FOR YOU!!!!
#33
Or you just put another dab of paint on it when you are done...or do the crank pulley. But on this engine it doesn't look like you could go much bigger on the crank pulley because there isn't much room left.
#40
It also appears to have a Vaccum to Boost ratio referenced bypass valve that has an electronic control valve. These are the black lines that run from the manifold before and after the supercharging chamber to the control valve, which is to the right of the throttle body connection. Could be that they will have the PCM control the availability of boost to the motor?
