Finally Found An AWD Dyno - What Do You Think?
AWESOME! Thats a killer combo.
Just for reference I have 0-60 and 0-100 times from a lot of my logs. on the 11.4 my 0-60 was about 3.3 and 0-100 was close to 8.2. It makes sense... my 1/8 mile was at nearly 95MPH and basically 7.3.
This is the clip of the 11.43 with the 0-60 and 0-100 mentioned above.
In this video I detail out those times and I ran 11.99.
With a 0-60 at 3.5 seconds I would guess you're damn near an 11 second pass. Of coirse the 0-100 time kind if dictates that more, but 9.7 seems slow if 0-60 was done in 3.5. After all the whipple is known for better top end efficiency than the Maggie is. I just realized when you watch that video on a phone the times don't pop up. I'll have to check back tomorrow and edit my post.
Friday the 13th Strikes
This is what I get for saying things were going well. Little surprise when heading to work this morning. Lucky that I wasn't jumping on it and not on the highway.
No, it was the bolt that holds the pulley mount to the front part of the jackshaft that broke. Whipple says they've seen it a couple of times with their high HP COPO Camaro applications and they started using an ARP 2000 bolt for those.
It had to be the heavy duty tensioner that caused it, the original design worked fine on stock Camaro applications but they came out with a heavier duty version for bigger applications.
Hopefully they will warranty it, it should not have failed being it was all their designed components.
Instead of a trophy shelf in my garage I have one that holds parts from catastrophic failures. I think I need a bigger shelf...
I think I might have the upgrade that bolt myself.
Blower is off and being shipped back to Whipple today.
