First alky injection impressions
#41
How do I change this text
Originally Posted by parish8
the way i understand it the 3 adjusments are.
1. turn on psi
2. initial pump speed(spray volume/presure)
3. ramp up speed as boost increases(gain)
i have twin 15 nozles. turn on psi is around 4psi. inital is about 1/2 and gain is set to max but i have a 3bar map so at 20psi(2.5bar) i might not be at full pump speed.
1. turn on psi
#43
Originally Posted by thunder550
BTW, kbracing96 helped me decide to go back to running 100% meth instead of water. I am running 100% water right now and it's not getting me hardly anything. I was hoping for significant cooling of the intake charge, but have seen only a slight drop in IAT's.
FWI, I have a Devils own kit and it easier to setup I think. Its just 2 ***** on the little controller. 1 is the turn on point, I have it set at 2 psi and the other is the full on, and it's set at 6psi.
Here is the controller
Here is where I mounted the pump
And here is where I taped the washer tank.
And here is where I put the 2 nozzles, never mine the MAF, it only there for the temp sensor.
#47
I hope to make it to the track Friday. I also hope to confirm my SOTP meter with some hard data at the track.
Plan is to run it just as it is, very rich. Turn the alky off make a run. Alky back on and start pulling fuel to get AFR inline. Of course logging each run.
I'll post up the results.
#48
Crap, left work bit early yesterday, packed up the soft drinks, chairs, kid and made a dash to the track. Get there ,1.5 hours away, and they are having a big 3 day event. Place is PACKED. No test and tune. Guess I should have checked the schedule huh?
Did get me 5 gallon of methanol while there. $3.00 a gallon. Since we'd driven that far we went in watched a few bracket races. My 7 year old really loved it. "Dad, why doesn't your truck do wheelies?" Dad, your truck is slow. From the mouth of babes....
#49
My 7 year old really loved it. "Dad, why doesn't your truck do wheelies?" Dad, your truck is slow. From the mouth of babes.... [/QUOTE]
LOL I know exactly what you are taking about. Everytime i take the kids to the sitter my 2 1/2 year old son thinks I should do burnouts and hole shots in the tahoe. He kills me, lolol. He loves to go to the drag races. He counts down the tree and everything. I think he is more into it than I am.
#50
alkcontrol is the best meth kit on the market!
I have never seen one out perform it.
some of the fastest turbo/blower cars in the country are running the alky control kit~!
