First set of pics....Alkycontrol install
So you got your tranny back in huh , thats good to hear .
Hey what are you running in your meth kit ? Straight Meth , 50/50 , -20 washer fluid , or just distilled water ?
thanks for the pics also !!!
Originally Posted by thunder550
I'm running 60/40 water/meth
Thanks, Jim
High on diesel fumes
I remember reading something about 100% meth reacting weird with the coating on the Radix rotors. I have also heard that 100% water is not good for them either. Someone recommended the 60/40 mix, and I think they said that it would be better for the rotors, and apparently the water cools the charge better than the meth, but the meth raises the octane. I don't really know a whole lot about the properties of either, so I just went with the mix that was recommended on the board. Plus 60% water makes 5 gallons of meth last a lot longer
I wouldn't be opposed to changing though if there was a good reason to.
Yeah THUNDER........... I love my ALKYCONTROL Kit Julio gives great customer service and his kits come with all the hardware needed. I mounted everything so you can't tell I even have the kit on truck. The pump I mounted on a plate and installed it behind the driverside headlight, and I put a new windshield washer tank to hold my Alcolhol, and than all of the braided lines we put a plastic covering over all of it so it looked factory. The kit turned out great...
what I'm interested in is, what is your consumption rate under different circumstances? any data?
Not really, I haven't played with the settings so it starts spraying at 4psi, and that makes it go quick. I usually have the kit turned off because of that. I am going to turn it up to 6psi whenever I get un-lazy, then I'll leave it on all the time and see how long a tank lasts me.
So how do ya'll adjust when the meth kicks in? Is it a Hobbs switch or is it an electronic controller?
