First set of pics....Alkycontrol install
So you got your tranny back in huh , thats good to hear .
Hey what are you running in your meth kit ? Straight Meth , 50/50 , -20 washer fluid , or just distilled water ?
thanks for the pics also !!!
Originally Posted by thunder550
I'm running 60/40 water/meth
Thanks, Jim
I remember reading something about 100% meth reacting weird with the coating on the Radix rotors. I have also heard that 100% water is not good for them either. Someone recommended the 60/40 mix, and I think they said that it would be better for the rotors, and apparently the water cools the charge better than the meth, but the meth raises the octane. I don't really know a whole lot about the properties of either, so I just went with the mix that was recommended on the board. Plus 60% water makes 5 gallons of meth last a lot longer
I wouldn't be opposed to changing though if there was a good reason to.
Yeah THUNDER........... I love my ALKYCONTROL Kit Julio gives great customer service and his kits come with all the hardware needed. I mounted everything so you can't tell I even have the kit on truck. The pump I mounted on a plate and installed it behind the driverside headlight, and I put a new windshield washer tank to hold my Alcolhol, and than all of the braided lines we put a plastic covering over all of it so it looked factory. The kit turned out great...
what a rush!
what I'm interested in is, what is your consumption rate under different circumstances? any data?
Not really, I haven't played with the settings so it starts spraying at 4psi, and that makes it go quick. I usually have the kit turned off because of that. I am going to turn it up to 6psi whenever I get un-lazy, then I'll leave it on all the time and see how long a tank lasts me.
So how do ya'll adjust when the meth kicks in? Is it a Hobbs switch or is it an electronic controller?
