Flat Spot or ?
Old 08-26-2006, 09:20 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Default Flat Spot or ?
From a standing start all thru 1st, and second, which shifts into 3rd at 92+mph it is a constant steady pull. When I make shift into 3rd it pulls, flattens and then starts to pull hard again.
Is this the TC locking up or ? It happens at about 4400rps +/- and only after 3rd.
Old 08-26-2006, 11:26 PM
TOTM: January 2007
Last Call's Avatar
I think thats the ratio in the trans.
My 5.3 w/ 4l60 did the same thing. It sucked. From 90-110 was dead!
Old 08-27-2006, 09:02 AM
Sounds like it's the convertor locking to me.Are you running the stock Radix tune or do you have tuning software?
Old 08-27-2006, 09:04 AM
trever1t's Avatar
Tuning by Rick@SynergyMotorsports. Feels like the converter locking. I can have him tune it to not lock, right?
Old 08-27-2006, 09:14 AM
Yes you can,but you probably just want to delay it,because you actually can put more power to the ground with the convertor locked.If you delay your lockup until your motor hits the sweet spot in the powerband your trapspeed will be higher.What gearing are you running and what rpm are your shift points?
Old 08-27-2006, 09:40 AM
trever1t's Avatar
4x4
Gearing is 3.73
Shifting at 6600 rpm
Peak hp = 6300
peak tq=3700
TC=2800
Old 08-27-2006, 10:12 AM
You are hitting a flat spot with the big drop off in gearing going into 3rd gear,the convertor is extending your rpms from 4000 to 4300 rpm,you need a bigger convertor with more shift extension.4L60E transmissions have a huge gear spacing from 2nd to 3rd.A set of 4.10s would help too.What kind of 1/4 mile trapspeed are you seeing?
Old 08-27-2006, 06:14 PM
spinz71's Avatar
It is the hydrualic lock-up in the converter. I had the same question when Dave at Rock On was tuning my transmission. Thats what he told me.
Have you checked you speeds when it happens? What caught my attention was that the rpms went flat but the mph continued to increase. Someone else posted about this a few weeks back also.
Old 08-28-2006, 09:53 AM
trever1t's Avatar
Feels like converter,
It shifts, pulls hard (now in third) goes flat, and then pulls hard again.
Old 08-29-2006, 01:17 PM
duwem's Avatar
Man, my car is unloading in thrid...
Its your fuel map, you have a nasty hole...
I would fix that before you blow your intake mainfold bolts!!!!!
Quick Reply: Flat Spot or ?
