Forged Pistons option for LQ4
I have a bone stock LQ4 that I want to upgrade my pistons and maybe my rods for a turbo application. I crushed two ring lands with a bad tune. I don't plan on running more than about 15 psi of boost so I don't think I need to change my CR. My engine has the floating wrist pins not the pressed in ones if that matters.
Does anybody have part numbers or recommendations for me or a vendor that would have this information? I don't plan on sending the block to the machine shop I'm just looking for standard replacements. Thanks in advance!
Baltimore Whore
Check into wiesco or Diamond.. They are prob the most popular choices.. There are plenty of other good names out there, be these 2 are among the most commonly heard.. give TSP a call.. Whats up to a fellow Md'er
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
11 Second Truck Club
I am going with autotecs, company started and operated by the original owner of JE pistons, which is an excellent reputation in the top performance market. Good price too. Wiseco, diamond, mahle, there are a few good pistons out there. I would at least dingle hone it if you are putting new pistons and rings in there...
In my opinion, the right way is the only way when you do this stuff. Its one thing to run a junkyard motor with a turbo, but if you are putting any money into the bottom end, do it right or don't do it at all. New pistons and rings in glazed cylinders is going to give a horrible ring seal, not balancing the rotating assembly is asking for trouble, and 15psi with a decent combo of supporting parts is nothing to sneeze at, many people have destroyed good motors with much less power. Also, those stock ls2 style rods are pretty strong, but they are heavy, that will make for a little sluggish feeling as far as rpm response, scat I-beams are $300, stronger and lighter than what you have. I have the same engine as you (06 lq4 with a cracked ring land) and am building it for pretty much the same thing you are. I have talked to a very reputable engine builder about it, and am confident in what he is setting me up with. Pm me if you want some more info.
9 Second Truck Club
Dingle ball honing a straight bore works great, and seals well, if done right. Bore needs to be cleaned really well with a green scotch brite pad after. I'm working with AutoTec and have designed a custom tight running 4032 boost piston for this application. They can build it .0015'' over, or 3.9995 where it will run in your factory bore. Piston will also have a .350'' thick deck, top ring .300'' down, .100'' longer skirt(for reduced rock) a 7.5cc dish volume, and close to std weight. You can PM me for details if you like.
thompson
09-30-2015 09:48 AM
