Front mount turbo
Old 08-14-2007 | 08:30 PM
usarmyman's Avatar
Default Front mount turbo
First off, do you have to run the turbo off of both banks or can you just use one. I have herd that you can turn the stock manifold upside down and use it as a turbo manifold, is this true? And how much boost can a stock motor handel. I was thinking of running 6-8psi on street and around 10 on the track.
Old 08-14-2007 | 08:35 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Both,
Yes,
That'll be fine..
Old 08-14-2007 | 08:36 PM
IMD's Avatar
IMD
Banned
i guess technically you dont have to run both banks to the turbo.....but that would be retarded. with some work you can use the stock manifold on the passenger side flipped over and turned around. you'll still have to make some custom pipe with a turbo flange to go between the turbo and the manifold. you will also have to find a way to connect the other bank of cylinders exhaust to the turbo.
Old 08-14-2007 | 08:38 PM
usarmyman's Avatar
Thats what I thought. Never hurts to ask tho.
Old 08-14-2007 | 09:04 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You do if you want the engine to survive long.
Old 08-14-2007 | 10:53 PM
WJ MARK's Avatar
Why don't you get a manifold from a Typhoon?? Im sure there is still some out there for a decent price.
Old 08-14-2007 | 11:14 PM
truckmann's Avatar
I don't think a V6 manifold will work too well on a V8
Old 08-15-2007 | 07:58 AM
WJ MARK's Avatar
He has a v6
Old 08-15-2007 | 07:59 AM
WJ MARK's Avatar
I wasn't sure if he was planning to do this before he did a 5.3
Old 08-15-2007 | 09:01 AM
truckmann's Avatar
Ya I think he may already have the 5.3L waiting to go in and is rounding up parts to get everything installed as soon as he can. He will have to comment on that though.
Quick Reply: Front mount turbo
