front mount turbo vs. magnacharger for DD
#56
The question really isn't if you can get in the boost. The saying from the other member is that he preferred the 1900 for DD. My motor is stock for the time being, so I really don't forsee needing the extra boost capabilities of the 2300. But maybe it is more efficient at the same boost levels and produces less heat?
#57
Restricted User
i wouldnt put a 2300 on a stock truck anyway. the 2300 starts to shine above 10 psi and 1900 for a daily driver is fine.
Truck up here at the track runs 11.90s with the tvs 1900 on his nnbs
4.10s
drag rads
yank sc3000 stall
long tubes
true duals
custom tune
meth
running 8 psi.
4.10s
drag rads
yank sc3000 stall
long tubes
true duals
custom tune
meth
running 8 psi.
#59
4.10s
drag rads
yank sc3000 stall
long tubes
true duals
custom tune
meth
running 8 psi.
4.10s
drag rads
yank sc3000 stall
long tubes
true duals
custom tune
meth
running 8 psi.
#60
A TVS2300 doesn't need over 10psi to shine. At 8psi we made over 550RWHP with a 6.0L at work and Allen Nelson made 672RWHP at 8psi. Mike Mcginnis made around 615 or so at 10psi and when he uppped to 14-15psi his gain was minimal. More boost doesn't always make big power. Just some examples, but the point is the TVS2300 makes plenty of power at 8psi and just because it will make the higher boost, it doesn't have to in order to make good power. Too many are concerned about the boost number over the results from the boost number. I've also driven both and would take the TVS2300 over the TVS1900 for that cubic inch level. The TVS2300 made boost just fine around town when needed. I have logs showing this. I couldn't buy a blower knowing that if I wanted to turn it up I'd have to overdrive it. A 6.0L that already has ported heads and longtubes is only a good camshaft away of making it hard to achieve 10psi without going to a bigger crank pulley on a TVS1900. Some would argue this, just look around at those using it.
Even if you don't plan a high power rig, your market, should you decide to sell, is bigger with the 2300. What's the price difference between the two?
