fuel pressure drop under boost
OK heres my problem.At idle and just above pressure is fine ,as soon as it goes under boost,pressure drops to low 50s I replaced the intank and the inline both and taken it to be dynoed tuned twice and both times same thing. Now the intank pump works and the inline is out again.So Im gonna replace the inline with the walbro 255 and pitch the second one from THE KIT. I know ive read something about this same problem a while back but i cant find it anywhere. Obviously the pumps ive gotten from the manufacturers kit blow but could something else be causing this, FPR?
Originally Posted by 02sierraz71_5.3
Ive seen several posts about the fuel pumps that come with the kit going bad, Im sure theyd come up with a search
Originally Posted by vanillagorilla
I bet its a regulator issue. If it's ONLY losing pressure under boost then it sounds like the FPR isn't doing it's job.
ooooffff and replacing pumps in the mean while. Yeh check that fpr. I believe, may be wrong with the new kits, but the radix inline pump is a walbro 255. If it goes bad, it's a fluke or your stocker went out first and the inline was just running on lots of air and overheating.
Originally Posted by BlownChevy
have you checked your fuel pressure regulator? Have you checked the wiring on the pump? Have you made sure the ground is good for the inline?
tell ya a secret...I went through 2 as well. Even though I did go through it myself, it is hard to believe we can have to product failures in a row...I hear ya man, feel your pain
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
