Fuel pressure dropping with key on????
Old 06-08-2010 | 09:07 PM
chevyridinhigh22's Avatar
Default Fuel pressure dropping with key on????
Hey, with my stock injectors in and the walbro 255 installed with key on it would hold about 58psi on the gauge. Running about the same 58 psi. Right before Wheatley tuned my truck with the procharger I installed 44# 8.1 marines in the parking lot. Jumped in the truck and turned key on and pressure would fall all the way to about 5 psi in a matter of seconds. What could possibly be the problem??? Even showing 5 psi on the gauge, turn the truck over, starts no problem and holds 60psi... Wot 64ish. Will not hold pressure anymore with the key on???? Any help welcome!!!
Old 06-09-2010 | 12:22 AM
1BADAZZSS's Avatar
Could be a injector stickin open.
Old 06-09-2010 | 12:25 AM
Dewey's Avatar
if those are ebay injectors, i've heard of several people having problems. if you bought them on eBay, then contact the person you bought them from. +1 on the stuck injector.
Old 06-09-2010 | 12:26 AM
What can I do to remedy that? Lucas fuel injector cleaner?
Old 06-13-2010 | 02:46 AM
There def. not ebay injectors... How can I find out if thats the problem? clamping the return line?
Old 06-13-2010 | 07:50 AM
04SilverCrew's Avatar
If you have someone that has the good snap on scan tool you can watch each injector on the screen. If one is leaking the others will compensate for that one. (hard to explain but easy to watch on screen) I used one on my wifes Pontiac to fix a hot start problem. We found an injector leaking down. Used GM injector cleaning procedure and have not had a problem since. All this can be done at a dealership.
wrb002
08-31-2015 12:00 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
slowlsx
07-13-2015 04:18 AM
Quick Reply: Fuel pressure dropping with key on????
