Fuel pump/Fuel system questions
Old 08-30-2010, 05:57 AM
  #21
GFYS and STFU
Spoolin's Avatar
I have a Lonnies twin in tank that feeds the stock fuel lines, Y-into the back of the fuel rails and then out of the front -8 to the FPR which has a -10 back to the stock return line. Similar to blown06's set-up.
I'm looking to change it all up here in a few months though.
Old 08-30-2010, 10:02 AM
  #22
sureshot's Avatar
What are you going to go with for your new fuel setup?
Old 08-31-2010, 09:16 PM
  #23
GFYS and STFU
Spoolin's Avatar
Plan on getting a new fuel tank, run the same pumps and throw out the stock lines and run -12 to the engine bay, and clean up the delivery and return lines.
Old 08-31-2010, 10:27 PM
  #24
Formerly darynC-10/23/10
Daryn's Avatar
i say run a bosch #044 intank. -6 feed , -8 return some fast fuel rails and a aeromotive bypass regulator
whole setup shouldnt cost you more than a grand
Old 09-01-2010, 01:06 AM
  #25
idahoblkss's Avatar
can you guys that know what your talking about post some part numbers and some links to where you get these parts, im also maxed out on my 255 intank with 60# injectors and was thinking about buying a aeromotive 1000 but i need to switch to a return style fuel set up and have know idea what parts i need. thanks
Old 09-01-2010, 03:44 AM
  #26
Daryn's Avatar
aeromotive 13109 is the bypass regulator i use. you will also need some #6 port plugs and port-to -6AN fittings.
Old 09-01-2010, 12:54 PM
  #27
idahoblkss's Avatar
so i will need this...
http://www.summitracing.com/parts/AEI-17151
and what else to make my truck a return style fuel system ?
Old 09-16-2010, 05:37 PM
  #28
anyone have pics of how they modified the basket to fit an 044? Im lloking at doing this to my old basket to use in my monte
Old 09-16-2010, 06:58 PM
  #29
sureshot's Avatar
Mangled made a sticky in the GM General Discussion section when he installed his 044.
Old 09-16-2010, 08:13 PM
  #30
Found it.. Thanks!
I knew it was covered somewhere, just couldn't find it.
Quick Reply: Fuel pump/Fuel system questions
