Fuel pump questions and more...
Old 12-20-2010, 02:42 PM
04SilverCrew's Avatar
Default Fuel pump questions and more...
So I have a returnless stock fuel system with 44lb injectors. I am running 8psi with a p1sc procharger. What can I do with a returnless system? If going with a walbro or bosch, those all need to be setup as return style right? Would i need to add a check valve? I have been using the hell out of the search but can't come up with a definate answer.
If I ever went to return setup, could I use the factory feed line as the return? Just trying to find the best but cost effective way to make sure I have the fuel this engine needs. She's a daily driver so keep that in mind. Thanks.
Old 12-20-2010, 02:49 PM
black04's Avatar
You dont need to convert to return just yet. You can run a walbro in the stock bucket. moregrip is selling the magnacharger walbro kit that is a complete replacement for your truck.
Old 12-20-2010, 02:51 PM
black04's Avatar
Here is the link
https://www.performancetrucks.net/fo...d.php?t=473873
I am running the same walbro pump on my returnless system making 510rwhp.
Old 12-20-2010, 03:07 PM
Now are you using the stock wiring or a 10-12 ga kit with a relay? Will that pump have priming issues? Aka... need a check valve? Or be ok as is? Sorry for all the questions... only want to do this once.
Old 12-20-2010, 04:22 PM
Formerly darynC-10/23/10
Daryn's Avatar
a single walbro 255 can support like 600 hp
Old 12-20-2010, 04:52 PM
black04's Avatar
The pump should have a built in check valve. Mine works like stock and i don't have a relay. I just took apart the stock connector and reconnected the walbro connector so that i wouldn't have to splice any wires.
Old 12-20-2010, 05:25 PM
That's badass! I don't like splicing into the factory stuff either. Makes for a nice clean install when all done. I sent a pm for the pump. Thanks for finding it. I plan to throw in that pump then head to the Dyno.
Old 12-21-2010, 06:01 AM
guero68's Avatar
If you wait a few months aeromotive is coming out with replacement drop in pump that out flows the Walbro 255 ....look it up 340 Stealth pump Aeromotive...
Old 12-21-2010, 07:46 AM
Rick_Vor's Avatar
They're pretty impressive and should be available by the beginning of February.
https://ls1tech.com/forums/fueling-i...tank-pump.html
Rick
Old 12-21-2010, 08:28 AM
I'll wait until they have been on the road for a while... right now there are no opinions or real world tests from guys like us! Plus I don't think my truck will need more fuel than the walbro. But it does look good. Too bad she will be hidden within the fuel tank.
Quick Reply: Fuel pump questions and more...
