Fuel regulator for boost?
Alright - I've searched ith no luck so here go's -
Can the stock 6.0l truck fuel regulator that is located on the fuel rail handle boost? Or do I need to get one that will adjust with boost? Thanks.
The stock one on my truck works just fine. I have run it up to 12 psi boost pressure and see 68 psi or better fuel line pressure. I run a Walbro 255 lph inline pump and the stock in-tank pump and fuel lines.
from what I understand its actually a good thing the way the trucks are set up...as you go into boost the fuel pressure goes up or something like that...Kyle from KBRacing told me how it all works but its slipped my mind...Im sure one of the FI guys will enlighten us
lxcoupe
07-21-2015 02:12 AM
GMCtrk
07-17-2015 06:39 PM
