fuel system questions
Old 08-03-2007, 03:10 PM
  #31
vanillagorilla's Avatar
Ok, then tell Bill to PM me too.
Old 08-03-2007, 06:58 PM
  #32
GFYS and STFU
Spoolin's Avatar
Originally Posted by TurboBerserker
Yeah we've been calling it cavitation because it kinda feels like a boat cavitating
Sorry for the guys but it's somewhat related to fuel pumps. Cavitation, at least how I learned it in school is when a impeller/propeller spins at too high a revolution and causes an extreme low pressure point on the back sides of the blades, at which point the water/fluid flash boils. (there are two ways to boil a fluid, either heat it to it's boiling point or lower the pressure until it flash boils) As soon as the fluid boils, tiny air bubbles appear and when they make contact with a solid object it IMPLODES, taking a piece of that object with it. That is why on improperly sized propellers you will notice alot of "pitting" on the low pressure sides of the blades. It's hard to hear on small pumps and propellers but on large ones such as on ships and in Hydro electric dam's cavitation sounds like a million tiny explosions against the volute casing/surface of the impeller/propeller. Gone unchecked it will destroy a pump or propeller/impeller and depending on the fluid could create a serious problem. I have never heard of this happening with fuel pumps but thought I would share the definition of a cavitating pump/impeller.
When a pump starts sucking air it's called loosing vacuum.
Old 08-03-2007, 09:17 PM
  #33
That's exactly what it is. Get a pump that won't cavitate and you'll be a rich man. Or a submarine engineer.
Old 08-04-2007, 11:02 PM
  #34
TURBHOE's Avatar
ok say i want to convert to return style and i used the stock feed line which i gather from ls1tech is about a -6 line could i use a -4 return? i ask because i have like 20 feet of -4 in my shed. and what about the evap does it just stay there?
USMCvet0311
08-01-2015 07:45 AM
MS3Z
07-30-2015 06:17 PM
FlowmasterMufflers
07-17-2015 03:26 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: fuel system questions
