Garrett GT30
Started the buying process for my turbo setup today... heres the blow off valve and turbo charger.
comparison of 2 turbine housings. the bigger one (1.06 A/R) came mounted as you can see...the smaller one is a .82 A/R
aaaand i got trigger happy (inside of compressor)
!!! im excited... pics of wastegate soon
When I talked to STS about a remote system they recommended that I run a small intercooler. I think an intercooler could only help and give you more power via colder and denser air.
Thank you!
good call getting the manifolds done. get something installed to pull a little timing when you're in boost. have fun. oh, and that's not even close to being too big for your application. stick the .82 a/r on it for spool. should be almost perfect.
so i swapped the GT30R for a GT35R
extra turbine housing 1.06 A/R
Vortech FMU
Autometer Boost gauge
the turbo manifold is getting fabbed this weekend, still have vacuum line, intercooler, and an extra fuel pump to buy
soon shell be good to go!!
Vortech FMU
The specs for this turbo are...
compressor ind:61.4 mm, exd:82 mm, 56 trim, .70 A/R
turbine is 68mm, 84 trim, have a .82 A/R and 1.06
the turbine mounted to the turbo is the .82 A/R
some updates... got the intercooler and the turbo manifold ceramic coated
the coated turbofold matches pretty good with the coated JBA header hmm?
intercooler
I will be doing the full install this friday and saturday
intercooler
