Garrett GT30
#22
What is half assed about it?
#23
Hunt&Fisherator
It looked like the turbo just sat on one header and the other cylinder bank wasn't attached.
My turbo setup is a log on the pass side where the turbo mounts, with a stock manifold on the driver side with a crossover pipe between....
Should work ok the way you've got it there, where are you putting the WG?
#24
as for your ? about the wastegate, look closely at my turbofold... near the turbo flange
#27
very nice! i have a question, i ordered an oil inlet fitting for -4AN line, I have both a restricted fitting and a non restricted, which one should i go with first? the drain in gonna be -10...
#29
well this kind of sucks, found out one of my head gaskets took a ****, so since im gonna have to have one of the heads pulled, im gonna pull both and get them ported up with a valve job and get some bigger valves put in. so turbo install gets pushed back a couple weeks...
