go 90mm TB or go home?
Old 06-27-2006 | 10:33 AM
  #181
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Also, if you are among the few who have done this mod on an 01-02 ETC truck (blue/red PCM), you are guaranteed 100% throttle opening with the LS2 TB!
Here's a couple of shots of my 91 Z28 with LS2 stroker and Radix, using the 02 PCM:
Old 06-27-2006 | 11:00 AM
  #182
Speartech's Avatar
Originally Posted by 2005SSR6Speed
I know of a few 2005-2006 LS2 SSR's that are using the 2005 GTO computers. It is just an OS change and they work.
Ahh....yes the LS2 SSR does use the same computer as the GTO. So on a stock LS2 SSR the TB doesn't open all of the way?? That's interesting.
Old 06-27-2006 | 11:05 AM
  #183
leftcoast32's Avatar
FormerVendor
That is why HP Tuner is looking into a new table to fix the problem. The LS2 SSR uses a different TB that is only 85mm and opens to 100%. I converted to the C6/GTO TB and only get about 90-95% throttle blade opening.
In the the tuning software the TPS% on the SSR reads at 83% to get 100% ETC% while the C6/GTO TPS% reads 88% to get 100% ETC%.
Old 06-27-2006 | 02:26 PM
  #184
Holty's Avatar
Notorious BIG
are the hptuners guys really looking into this? if so, is there a thread on it already over there?
i still can't explain the differences in my tranny shifting after bolting on this mod. both me and zippy ran into this on atleast two different trucks. i would really like to see some sort of solution on this.
Old 06-27-2006 | 02:48 PM
  #185
FormerVendor
Here are a few threads on HP Tuners Forum:
http://www.hptuners.com/forum/showthread.php?t=6414
http://www.hptuners.com/forum/showthread.php?t=6454
http://www.hptuners.com/forum/showthread.php?t=6411
Old 06-27-2006 | 06:59 PM
  #186
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Thanks to John at Speartech for looking into this and posting up. Between you and Richard, we're getting spoiled...
Old 06-27-2006 | 07:13 PM
  #187
I AM A MOTHERF*CKER
BTW I saw Chris' reply to my question about HPT and editing the ETC tables. I was not talking about the pedal response tables, but rather the ETC MAX POSITION table in EFI Commercial. This table edits "Maximum throttle position that can be commanded."
I have the commerical version of EFI and will play around with this and a 90mm tb when I get a few moments (currently replacing tranny, converting to 2WD, likely changing rear end, etc. etc.... )
Old 06-27-2006 | 10:31 PM
  #188
DrX's Avatar
DrX
I am wondering how this combo is able to sort out the out of range WOT TPS signals generated by the LS2 TB. I can't see this happening without some change in the tune unless some kind of TP learning is involved. What vehicle is your calibration based on?
Old 06-27-2006 | 10:35 PM
  #189
DrX's Avatar
DrX
Are the PCMs the exact same part # (i.e they contain the same TAC chip)?
Old 06-27-2006 | 10:59 PM
  #190
FormerVendor
The only difference is the OS, I have installed the GTO computer in an SSR by just doing a full write.
Quick Reply: go 90mm TB or go home?
