go 90mm TB or go home?
Old 06-28-2006 | 11:32 PM
  #201
DrX's Avatar
DrX
Actually, the LS2 TB shouldn't work at all with the newer truck PCMs/OSs if the PCM could see the TPS signals. This is because the newer TB's dual TPS signals move in the same direction while the LS2 and 01-02 dual TPS signals move in opposite directions. I'm guessing that this would trigger a TPS correlation DTC. So the translation of the TP signals into %TP and the correlation checks have to be performed by the TAC module and then relayed to the PCM. So how is the same TAC module able to adapt to the wider sensor range in one application and not the other?
Old 06-28-2006 | 11:50 PM
  #202
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The TAC module change corrects the differences in the TP1 and TP2 directions but the PCM is where most of the "intelligence" of the ETC system is located. I think this is pretty much confirmed by the huge number of ETC tables that are contained in the PCM calibration.
Old 07-05-2006 | 11:44 PM
  #203
anything new on the tunning from hpt
Old 07-13-2006 | 06:02 PM
  #204
Bill Reid's Avatar
Bumpin' this one up... patiently waiting for the fix
Bill
Old 07-13-2006 | 06:06 PM
  #205
leftcoast32's Avatar
FormerVendor
Got a pm back from Chris at HP Tuner today. He says they have not found anything yet.
Old 07-13-2006 | 06:34 PM
  #206
Bill Reid's Avatar
... as long as they are still working on trying to figure it out thats cool...
Bill
Old 07-14-2006 | 10:14 AM
  #207
moregrip's Avatar
what a rush!
maybe we can re-gear the TB's if the tuning does not pan out. any watchmakers in the house?
Old 07-14-2006 | 10:59 AM
  #208
wkdivr's Avatar
Grippy, did you, or BC notice the same deal with the blade opening less than 90 deg.? I'm wondering if it only is affecting to 6.0 cal, and not the 5.3. I haven't put mine on, yet, still in Afg.
Old 07-14-2006 | 11:03 AM
  #209
moregrip's Avatar
what a rush!
BC says his opens 100%, when I did the test on mine it did not open 100%.
Off Topic: It's been crazy over here(NAVY) with support over in your general region lately
Old 07-14-2006 | 11:04 AM
  #210
BlownChevy's Avatar
blownerator
you could not do that, it will set a TPS code.
Quick Reply: go 90mm TB or go home?
