go 90mm TB or go home?
Old 06-08-2006 | 02:10 PM
  #51
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by Holty
that is correct, i could not really feel any difference after adding the timing.
cuz it(ECM) was pulling it(those 5 degrees) back away...kr.
Old 06-08-2006 | 02:12 PM
  #52
zippy's Avatar
You've pretty much got that right on. If you can run 17º for example from start to finish then you could have ran maybe 21º off the line and tapered it down to 17º by the finish line.
  #53
dewmanshu's Avatar
Originally Posted by krambo
On a cammed radix'd 5.3L maybe. On a properly tuned (prior to 90TB) radix'd 6.0L, You will not see that increase. Every application is different. I think that is key here.
I am running 19* overall timing with meth and am hitting a bit of KR in the 5K range.
really? what % meth are you running?
Old 06-08-2006 | 02:28 PM
  #54
krambo's Avatar
49/51. IAT's during my dyno runs started about 120 and finished 128. I can't remember the jet size but it was properly sized. I am running the 2.8" pulley on a 364CID making roughly 9psi.
I am thinking I am picking up false KR from somewhere. I am in the middle of playing with pulley sizes and timing. I think the KR is somehow coming from the converter engaging.
Every application is different. Spraying meth in pre-compressed air (radix) vs. compressed air (turbo) is very different IMO.
Old 06-08-2006 | 03:13 PM
  #55
thunder550's Avatar
High on diesel fumes
I am running 21* timing on my LQ9 through most of the RPM band, then it backs off to 18* above 5500 RPM - no KR at all. IAT's at the end of the run in the high 130's, 100% water spray. No meth. And those timing numbers are actual spark, not commanded.
Just for comparison sake. And yes I am using the IAT spark correction table (thanks zippy, hope you don't mind if I borrowed a little bit from the tune you sent me....)
Old 06-08-2006 | 03:31 PM
  #56
BlownChevy's Avatar
blownerator
So, when you are at the line, light goes yellow, what is your IAT?
What spark are you commanding?
How many #'s of boost?
Then at the finish, crossing 1320 what is your IAT?
spark? (I imagine for you it's the same as when you started, cuz you have it like that jk)
boost?
With whatever you answer with I am gonna suggest extra timing at the green light to produce a better 60'...but my suggestion isn't gonna be any good for when you cross the 1320, it'll be too high. Hence Zippy's add some timing down low while it's cool and you get away with it. I don't think the arguement is you can't get the same degree from the beginning to the end, I think the debate is, you can get more timing in the beginning for more power but taper it off back to a safer degree once the IAT starts to heat back up.
My timing out of the hole is -25* and 22* through the traps.
Last I checked, the IAT's were in the 116 range outta the hole and 145-150 through the traps. The boost is 8.5-9 approx (digital gauge)
Old 06-08-2006 | 04:15 PM
  #57
zippy's Avatar
It works for me. Glad I could help. How are you liking your Nick Williams 90mm?
Old 06-08-2006 | 04:21 PM
  #58
thunder550's Avatar
I like it so far, but I can't comment on any results directly from the TB, since it went in with the 6.0. The only problem I am having is trying to find the correect clip to hook up the cruise control. There is still a ton of tuning I can do, but I have been putting it off since I am pretty sure that I have a leaking intake manifold gasket. Got a new set at home, just need to find some time install them. I need to make an appt with a Mustang dyno shop and go do all my VE tuning and base spark table tuning in a controlled environment, then I can mess with the spark tables, IAT VE multiplier (it runs lean when hot and rich when cold, go figure....), and IAT spark tables some more out in the "real world".
Old 06-08-2006 | 04:33 PM
  #59
wkdivr's Avatar
Originally Posted by zippy
An example of working with the heat tables is Holty's truck. He ran a: 12.667@105.60 1.801 60' with an AWD Silverado SS. Those numbers are with a stock camshaft, stock stall speed, and 20" wheels. Working the tables is the only way you're going to be able get a Radix truck to have enough timing to get that hard of a launch and still be pulling out the big end without KR* pulling all of it's timing.
I'm starting to like your line of thinking! I also like you ideas on trans tuning. (you posted something on that subject a few months ago, and it stuck in my head ever since!) I'm leaving for Bin Ladin land tomorrow, but you'll likely be hearing from me come Sept.
Old 06-08-2006 | 05:17 PM
  #60
dewmanshu's Avatar
A clean 22* through the traps with the crew cab is pretty impressive IMO. What I meant on your timing at yellow (should of said green) is when you floor it, what are you commanding? WHich if you are saying you are ending at 22* and you already said you finish as you start...that answers my question. Soooooo you don't think you couldn't get a few more horses out of the hole with another 2 degrees? Just the 60'.
And if...a BIG IF you thought you could get another "X" ponies or so out of the hole, just goto the IAT spark correction table and add 2 degrees up to 125*(I don't have the table in front of me or I'd be more specific about the column temp) then from there on up keep it as is since the finish is working for ya.
Quick Reply: go 90mm TB or go home?
