Going for big boost on a forged 5.3
My pistons should be here friday from wiseco, but i still need to get some head gaskets... The guy from race engineering where i bought the pistons from told me that my compression will be 10.4 to 1 with the pistons and the 61cc chamber in my stock heads with a stock gasket....
Dont know too much about compression ratios, but i do know too high with forced induction is not good....
I wana get around 15lbs of boost which is prolly max for the blower can i leave the compression ratio where it is at 10.4 to 1 or does anyone make a aftermarket thicker head gasket to drop the compression ratio?????
Also would you guys recommend using arp head bolts too?
Hunt&Fisherator
Look up Cometic and see what they can do for the thicker gaskets.
ARP head studs would be a must as well for reliabilitys sake.
As far as the heads are concerned, 317s will cause valve shrouding on that small of a bore. I'd personally do some 243s... Shoot for a compression ratio for a hair under 10:1
Could Wiseco put bigger valve reliefs or a dish in them maybe to drop some compression??
