Good Cam for force induction
You should rephrase that by saying you want a cam with little overlap since every cam has overlap in it. Its how much you want and are willing to put into a setup that matters.
R
You should always look at the overlap at .006 as well.
R
I am going to recommend a crane low lift 212 218 531 531 114 if you want to go a off the shelf route.Only cause I know that particular motor seems to work well with that camshaft.
Or go with a custom grind maybe speced by rick if you want.It may cost a little more but,probably work better for you.
What ever you get don't worry about bigger duration higher lift a smallish cam under 220 duration and 550 lift on both ends.Keep lobe sep. in between 114 to 116 and you will get by just fine.
