Got my ebay roush tvs today
#151
KB makes a puller and pulleys that look like they might work. If some pressed it on I'm sure it will come off.
I"d rather run on the safer more conservative side than on the ragged edge of self destruction. Sure I'll probable take my truck to track but by no means am I trying to but a max effort boosted engine. This is my DD work truck, the main reason I'm doing this is for more pull power to tow my camper.
BTW, another supercharger company that I will not name in public sold me the TB adapter I wanted. It was very inexpensive so If it doesn't work out I'll have one made.
#154
Truck Sponsor
I like the look the look of the kit. Whats the size of the IC? Looks like the intake tub has a lot of room in it. But might just be the pick.
You are correct if it was pressed on it can come off. A puller and sometimes a little heat from a torch and it will come off. If its pressed on, and rated for low boost it might not be keyed. If so you will want to key it when going back together, just a thought.
Hotrodding 101. "All things can fit and be made to work. With time, and effort you can over come anything."
Good luck with the project, Looking forward to the results.
#155
check out http://www.southfloridapulleyhq.com/...dub_system.htm
I am not a current user of the product nor do i know if it will fit the snout just came by the page and thought of you guys
#157
For those concerned about it having a pressed pulley and/or limited pulley options, here ya go... They can make what ever you desire..
http://www.rjmachine.com/pulley.htm
I have one of these kits going on a NNBS and should be up and running early March.. I'll post some pics once I complete the install..
06vortecmaxxx, good luck with the install, it will be worth it in the long run..!
_
_
