great info for you STS guys...
Originally Posted by hemifever
I have headers that are ceramic coated and don't really intend to pull those off. I thought about wrapping my exhaust from the y-pipe back to the turbo. But then figured it would get wet and continually steam from under the truck which I don't care for. Would heat paint help the straight pipe from the cat to the turbo?
On the paint, anything to keep the heat in the exhaust from radiating out of the pipe is going to be good.
glad to see you guys feeding off of this thread...
I remember from some training on steam operated tire curing presses where I used to work that heat has a direct relation to pressure and vice versa...if I remember correctly, the pressure rises somewhat parallel with the amount of heat being contained...correct?
I know who that guy "engineermike" is, he's from this area (his car is a stock appearing and sounding LT1 Camaro... until you hear the turbo spool) anyways...
I'm sure the temp made some difference, but think about this:
yesterday I was reading a thread about a guy that installed his STS kit and had to get to his tuner, but was afraid that at highway rpms he would be making boost and hurt his untuned motor. He was assured that as long as he kept the load to a minumum he would not be making boost, regardless of engine speed.
with that in mind: the original poster of this ls1tech thread also mentioned that he got a much tighter stall, call me crazy, but I'm willing to bet the when you try to accelerate hard through a tighter stall, your engine load just increased dramatically
I'm not an engineer, but this is what is logical to me.
ktmrider, ceramic coating will most definatley keep the heat in the tubing. It will keep the heat in far better than an un-coated header, but when compared to the stock manifolds, they have more surface and they're made out of much thinner material. These properties will make them transfer to the surroundings more than manifolds. If you painted, wrapped and painted them, I think you'd have the best of both worlds though. The warranty on your headers will be void though if you wrap them.
https://www.performancetrucks.net/fo...ht=headers+sts
there are others but i don't feel like going through them all they are mostly debates. but this has been talked about ever since the sts came out.
