GT67 on a 6L how many #s can it push?
Old 09-04-2006, 12:05 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Default GT67 on a 6L how many #s can it push?
Just outta curiosity
Old 09-04-2006, 01:05 PM
How do I change this text
Wilde Racing's Avatar
I'd say well over 15 psi, TurboBerserker should know for sure.
Old 09-04-2006, 01:08 PM
1slow01Z71's Avatar
Intercooled? Meth? All of the above most likely.
Old 09-04-2006, 03:53 PM
If you would want to run timming you would need both imo.
Now if you had a vic, J.R set-up. Then I think it would handle a bit more.
Old 09-04-2006, 04:25 PM
1slow01Z71's Avatar
The vic jr is sitting in a box in the garage just need the shiny accessories for it Can you pm me some details on your FMIC please?
Old 09-04-2006, 08:52 PM
quicksilverado's Avatar
I was running 12 psi on the 370 with no I/C. Was making right at 600 rwhp. I'm also running 12 psi on the 347 with an I/C. Don't know how much power its putting down, but its definately stonger than the 370 setup.
Old 09-04-2006, 09:54 PM
Did you run this on forged internals or stock bottoms?
Old 09-04-2006, 09:55 PM
1slow01Z71's Avatar
Wilderacing is running 12psi on a stock bottom end 6L, I think thats what Im going to shoot for since I dont need to blow yet ANOTHER motor
Old 09-05-2006, 09:23 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Stock LQ9 bottom end safe limit is around 12 psi. I ran that for a very short time (was out of fuel pump at the time) with only meth. If it's an LQ4 with the lower compression you might get another few pounds, but it would still be right at the limit.
Old 09-05-2006, 09:30 AM
Whippled 496's Avatar
I bet with a ranch hand front bumper you could push a few thousand pounds easily as long as it wasnt uphill.....
Sorry just ignore me.
Quick Reply: GT67 on a 6L how many #s can it push?
