for guys over 650 rwhp turbo or supercharged
Old 04-11-2016 | 12:13 PM
tim wellington's Avatar
Default for guys over 650 rwhp turbo or supercharged
main caps ,who running stock bolts and who running arp studs(after line honing).a engine builder was telling me u should always use studs on force induction engine over 10lbs of boost thoughts
Old 04-11-2016 | 12:21 PM
George C....'s Avatar
Formerly ScreamingL
If doing a fully built motor do ARPs
If boosting stock leave stock alone
With said if you rattle that motor youll flex that crank
Old 04-11-2016 | 01:56 PM
Vortec350ss's Avatar
Yea I would say its worth doing the studs if you already have it apart.
Old 05-20-2016 | 12:15 PM
Default back fresh studded
Had to ease my mind . Pulled engine out tore it apart and studded block with arp studs .Got back together and running 250 miles on it new build . after 500 mile going back to mobil 1 oil . conventional rottella 15-40 .Cant take the heat . My machine man said bearing were getting hot . Had to replace cam bearing .
Old 05-20-2016 | 12:38 PM
GMCtrk's Avatar
SBE all day long. Good fuel, good oil and let it eat.
Old 05-20-2016 | 04:10 PM
supermaro's Avatar
Originally Posted by tim wellington
Had to ease my mind . Pulled engine out tore it apart and studded block with arp studs .Got back together and running 250 miles on it new build . after 500 mile going back to mobil 1 oil . conventional rottella 15-40 .Cant take the heat . My machine man bearing were getting hot . Had to replace cam bearing .
You put main studs without line honing the mains
Old 05-20-2016 | 06:50 PM
03sierraslt's Avatar
Ya, this. I wouldn't change mains or rods that way.
Old 05-22-2016 | 12:01 AM
fullboardmax's Avatar
I picked up studs for mine while it's getting built. I actually went with arp for nearly every bolt on or in the engine.
Old 05-23-2016 | 08:33 AM
Default studs
never .HONED it.we check it with studs before and after HONED clearance change .001 on every cap except number 1 it stayed the same for some reason .
Old 05-23-2016 | 08:38 AM
Default arp
i am arp all the way now .head bolt instead of studs though .had no problems 15lbs of boost
01SilveradoJakee
37
06-09-2016 12:21 AM
BigBlock90
34
04-20-2016 01:48 PM
sledaction 198
04-07-2016 02:33 PM
LSX14
04-07-2016 02:22 PM
