Head Studs
If you're planning that much boost, I'm going to take a WAG and guess that you'll be into that motor sooner vs later. Studs are a pretty good investment at high boost levels. Hold better and reusable. I've seen stock bolts pulled out with the heads still on the motor, and replaced with studs one at a time on a high boost diesel (~40ish psi). Might be something to consider. No doubt, I'd do it if the motor was apart.
Yohns Kustom Fab
08-25-2015 06:53 AM
