Head Studs
Old 07-04-2012, 11:10 AM
black4.8's Avatar
15-16psi, 16deg timing, 93 &meth, 10.8afr, bref7 plugs. stock bolts and gaskets. i'm right at the point of lifting heads tho.
Old 07-04-2012, 11:48 AM
old motorhead's Avatar
If you're planning that much boost, I'm going to take a WAG and guess that you'll be into that motor sooner vs later. Studs are a pretty good investment at high boost levels. Hold better and reusable. I've seen stock bolts pulled out with the heads still on the motor, and replaced with studs one at a time on a high boost diesel (~40ish psi). Might be something to consider. No doubt, I'd do it if the motor was apart.
Old 07-05-2012, 10:38 AM
slowec's Avatar
Originally Posted by blue0453
Ive always heard and read 15psi as well. Im supprised you didnt just do it before you put the motor in Rodney, thats what I would have done.
I was on 10 psi and never took the valve covers off when I put my 6.0 in
Old 07-05-2012, 11:40 AM
1989k1500's Avatar
I have friends that have ran up to 24psi on stock bolts and stock gaskets.
Old 07-05-2012, 11:55 AM
nonnieselman's Avatar
i wanna say KBracing lifted the heads on his 4.8 on 16 or 18psi?
few more did on 15-19psi..
more timing will deff help the issue arise faster tho.
Old 07-05-2012, 07:03 PM
slowec's Avatar
I am currently running 14/14 timing/boost everyday on meth/93. Its to fun to stop...
Old 07-06-2012, 09:44 AM
If you ever seen coolant seeping from the head/block.. you will know something is up and time for gaskets/studs
Old 07-06-2012, 01:15 PM
slowec's Avatar
Yep! push it till it weeps a lil, let it cool, back it off a couple and let er eat some more.
Yohns Kustom Fab
08-25-2015 06:53 AM
JordanH
08-08-2015 07:59 PM
4B11T
07-13-2015 03:48 PM
ChevyLee
07-10-2015 10:56 PM
Quick Reply: Head Studs
