Heat shielding
Truck Sponsor
Turbo blanket
wrap down pipe
hear sleeve a/c low side suction line.
Those are pretty standard.
Wrapping the manifold help hold heat but also the wrap gets you closer to the wires.
Heater hoses should be anywere close to the hot stuff.
We have covered the oil feed line.
If your turbo is to close water tank you might need to cover tank.
But the blanket should solve most if not all heat issues.
wrap down pipe
Turbo blanket
wrap down pipe
Heater hoses shouldnt be anywere close to the hot stuff.
wrap down pipe
there ya go.
