Heat shielding
I've got the turbo blanket, log manifold wrapped, down pipe wrapped, crossover pipe wrapped to the bend, and pretty much all wires around that area are wrapped with heat tape. Turbo oil feed covered with heat sleeving along with the A/C low pressure hose. Heater hoses are also covered down by the waterpump.
Charlie Murphy!
I hate to ask for spoon feeding, but could you guys show me exactly what heat tape, turbo blanket, exhaust wrap you used? How much exhaust wrap and what size? How many stainless steel zip ties?
I'd like to do a little ordering and I'm not sure what products have been successful. Also, I'd like to keep everything black if I can.
Thanks!
Thanks!
Charlie Murphy!
I've been doing some searching. Does all this seem a bit over kill?
GM LS1/LS2/LS4/LS6/LS7 Spark Plug Wire Boots Black 8Cyl
http://bit.ly/18DyRZV
Would you guys do these or just use hose clamps?
10pcs New 4.6*300mm Stainless Steel Cable Tie MARINE Boat Strap Exhaust Wrap
http://bit.ly/12trgFT
Use this for the A/C line?
COOL TAPE 1.5" x 15' Roll - SELF ADHESIVE INSULATING HEAT BARRIER DEI 010408
http://bit.ly/18DAK8Q
NEW T4 BLACK TURBO CHARGER TURBOCHARGER BLANKET HEAT SHIELD COVER GT47 GT55
http://bit.ly/14y2GH2
2 cans of this?
DEI 010301 Exhaust Wrap Header Downpipe Silicone Coating - Black - High Temp
http://bit.ly/1aaCYhi
This is what I was thinking for header/downpipe wrap.
Black Exhaust Wrap Turbo Manifold Pipe Header Wrap 1/8"x1"x50' High Temperature
http://bit.ly/12j7Gv0
Exhaust Heat Header Wrap ONE ROLL w/ ties 1/8" X 2" X 50' Black High Temperature
http://bit.ly/1801e5h
Something like this for the oil lines?
Aluminized Wire cable loom heat sleeve braided steel sheath tube 1 1/2"x36" long
http://bit.ly/16W0ERa
2 cans of this?
Shotguntommy
09-15-2015 05:24 AM
