HELP! fuel pressure/ 9psi max boost b4 130% duty cycle.
HELP! fuel pressure/ 9psi max boost bc factory wiring won't feed pump?
I have an 03 silverado 6.0 78 mm turbo. 60 lb injectors , walbro 340 lph in the tank. I am currently running 9 lbs of boost. when i try and turn the boost up i cant bc its goin to 130 % duty cycle i think its bc the fuel pressure drop when i try and add more boost. stock lines. would running a 10 guage hot wire kit to the tank solve this problem completly or will i have to run a return line to the tank and put an boost reference FPR on the fuel rail?
any advice would really help. thanks
the injectors r working harder bc fuel pressure drops alot at wot in boost. 9 psi is as high as i can go and its at 73 % duty cycle there. any higher on the boost and it goes to 130% at 11 psi. hot wire kit 10 guage to the pump for more volts? will this solve the problem or will i have to get a boost reference regulator and run a return line to the tank and mount regulator on the fuel rail?
ferocity02 thank you for your advice. i think u r the only one that actually knows what im saying. so u think this will let the pump work to it capability and then i wont have this problem anymore. i should be able to get to 550 rwhp easily on my set up. im just trying to set the boost at 12psi and i was confused bc i know the pump and injectors are more than capable of that.
