HELP! fuel pressure/ 9psi max boost b4 130% duty cycle.
vortec350ss im running pump gas. at 9psi with 60 lb injectors im at 73 % duty cycle. i dont think the factory wiring going to the 340 lph pump will work past that bc of voltage drop. what im asking is if i do the 10 guage hot wire kit to the pump if that would be enough or will i have to run a return line to the tank and mount a boost referance regulator to the fuel rail.
Yes it's returnless. It is NOT a new build. I just recently tried to turn the boost up to go to the track and I ran into this on the dyno. So he set it back to 9 psi and it works great there at 73% duty cycle.
I'd try a Hotwire kit first. If you still have an issue, then I'd check for a burst or kinked fuel line in the tank. If that all checks out okay then I'd convert to a return style system. IMHO, return style with a vacuum/boost 1:1 regulator is the best for any boosted setup past 7-8 psi.
